REVIEW Community Review: AutoRaptor
admin
Administrator
96
1
DealerRefresh
Community Review: AutoRaptor CRM
Sourced from DealerRefresh forum discussions
Overview
AutoRaptor is an automotive CRM platform built to help dealerships manage internet leads, track response times, and monitor sales process performance. It holds GM certification as an approved lead management vendor, making it a notable option for franchise dealers navigating OEM compliance requirements. Based on community discussions, it is most frequently positioned as a straightforward, accessible alternative for stores that want a functional CRM without the complexity of enterprise-tier platforms.
What Dealers Are Saying — The Pros
  • GM-Certified Alternative: When dealers experienced widespread failures with OneSource's smartphone integration — which was failing to properly timestamp lead responses and costing stores on GM's 24/7 response time scorecards — AutoRaptor was specifically called out as a certified vendor dealers could migrate to in order to get back into compliance. That kind of real-world utility matters.
  • Simplicity and Accessibility: Community members who recommended AutoRaptor consistently framed it as a clean, approachable platform. For stores that have been burned by over-engineered systems or steep learning curves, that reputation carries weight.
  • Part of the Conversation: In a thread where a Honda-Hyundai store in upstate New York was actively shopping for a VinSolutions replacement, AutoRaptor made the shortlist of peer recommendations alongside Dealer Socket, ImagicLab, and Dealer.com — good company to be in.
Common Concerns
  • Reporting Depth: When the conversation turns to benchmarking, performance monitoring, and campaign management, veteran users and trainers tend to steer dealers toward VinSolutions or Promax. AutoRaptor doesn't consistently come up in those discussions as the power-user choice.
  • Close Rate Questions: One dealer shared that his store was running a 4% e-lead close rate on AutoRaptor. While forum contributors were quick to point out that data entry discipline and staff training are often the real culprits, the story did raise questions about whether the platform provides enough visibility to catch and correct those issues early.
  • Not Built for Advanced Analytics: Dealers who want to run deep data campaigns, segment their database, and produce granular performance reports may find AutoRaptor's feature set limiting compared to heavier platforms.
Notable Mentions from the Community
During the OneSource meltdown affecting GM dealers' lead response timestamps, AutoRaptor was surfaced as a certified escape hatch — a real-world endorsement that's hard to manufacture.
Trainer Jerry Thibeau's benchmarking thread made it clear that CRM selection matters, but so does what you do with it. The dealer struggling with a 4% close rate was a reminder that no CRM fixes a process problem on its own.
Overall Verdict
AutoRaptor earns consistent, if understated, respect from the DealerRefresh community. It's a credible, GM-certified option that solves real problems for stores that need a reliable and approachable lead management tool. If your priority is simplicity, compliance, or a clean migration away from a bloated platform, it deserves a spot on your demo list. If you're a data-driven operation looking to squeeze every percentage point out of your process metrics, you may want to pressure-test whether its reporting capabilities can keep up with your ambitions.
Bottom line: Demo it, talk to current users, and be honest about what your store actually needs from a CRM — that's the community's advice regardless of which platform you're evaluating.
The thread reviews AutoRaptor CRM, a GM-certified lead management platform marketed as a simpler alternative to enterprise-tier automotive CRMs. Dealers highlight its accessibility and OEM compliance credentials as key selling points, particularly for franchise stores that want functional lead tracking without complex setup. It positions AutoRaptor as best suited for dealerships prioritizing ease of use and internet lead management over advanced customization.
Replies Views 0 631 Started Last Reply
