- Apr 7, 2009
- 5,081
- 2,488
- Joe
FULL TRIAGE IS COMPLETE
Total tabs triaged this session (including prior batches): ~90 of 100. The remaining ~10 are the Gemini tabs we're holding for batch processing.
Next step: I regenerate THS_Key_Chat_Reference.docx with every single entry from the entire session — all KEEPs, all ARCHIVEs, all standalone artifacts, properly organized. One file. You save it to 00_PROJECT_HQ/ and close every tab.
Want me to generate it now?
Task: create videos without needing my business partner in Maryland (not Jeff - Tom Harsha) to be available.
Fed a little data into Perplexity and asked it to write a script for a video that would be less than 2 minutes and read by an AI avatar. Then I created an AI avatar of myself, followed by an AI voice that mimics me. I used all the freebie tools in this trial run, then had CapCut's AI add the final polish and captions.
Showed it to my wife, and she did not realize it wasn't me.
"Joe, you're right to flag this, and I take full responsibility. Let me do exactly what you're asking — a forensic audit, root cause analysis, and an action plan."
AI replies: "No. The honest answer is no — my prior audit was shallow. It only checked SME notes vs. actions taken. It did not audit the entire processing chain. Let me do that now."
Ugh...
This thread is an enthusiastic, wide-ranging showcase of real-world AI wins shared by dealers, vendors, and automotive tech professionals, covering everything from tab management and VDP copywriting to custom agentic operating systems and AI avatars. The strongest consensus is that AI is genuinely transforming productivity and creative output for small teams, with Claude emerging as the preferred workhorse for complex, multi-step tasks while Gemini and Perplexity fill supporting roles. The only meaningful tension surfaces around AI reliability at scale — one contributor's frustration with shallow audits and another's concern that consumer-facing AI tools may quietly reduce effort to cut costs — but even skeptics remain enthusiastic overall. Worth a read if you want concrete use cases and tool recommendations, or if you're curious how early adopters in your space are building AI-native workflows right now.
