HomeNet Users - having trouble uploading photos?
eag818
Skate Alert
Jan 21, 2010
51
4
Hubert Cumberdale
Take pictures. Bring into LightRoom, then Photoshop. Move to an output folder, zip up. Upload to HomeNet and.... Oops! This link appears to be broken.
fml.
Do other Homenet dealers have this problem on occasion?
HomeNet actually has 4 different photo upload tools. The .zip file method is the second most cumbersome next to uploading photo by photo. I would forget the .zip method all together.
Just above the .zip file section is a large button that looks like an ad for a camera, it's actually a button for the third method. This is the aurigma image uploader, an industry standard at one time,. Very simple to use. You will have to download an active x control before you get started. When the tool appears you will have your folder tree on the left, select the folder your photos are in then they will appear on the top section of the large box. Drag and drop the photos to the lower box then hit send. You're done with that car.
I use the 4th method, Photocaster 2. It's a small program that you download on your computer. Here is the link, I use it often so I have a desktop icon. Set up takes the longest then it's smooth sailing after that. Photocaster 2 can be set up so that only vehicles in IOL that need dealer photos show up. Then you can set a path or folder for it to always get your photos from. There are several different naming conventions you can use to tell the photos where to attach themselves i.e. stock#(1).jpg, or vin#(1).jpg. I don't use a naming convention, I use the drag and drop method. The photos appear on the right, the vehicles on the left. Just drag and drop the corresponding photos to their vehicles, keep your control button down for multiple photos. Then when you are done attaching all of the photos to all of the cars then you upload them. It's not a car by car upload. It saves so much time not have to wait for images to upload on a car by car basis, they all upload at once.
Like I said, set up takes the longest. Now we take about 15 photos of every vehicle @ 1280x960 and 50 vehicles takes less than 10 mins.
You can email me if you have any questions or I'm sure HomeNets CS would be happy to help.
Autoarchitech is right. My employees time stamp too. I was just going on the assumption that you didn't use iol2go. If you can pick up a device with windows mobile 5.0 or higher, and a screen resolution of 240X320 or equivalent, (320x320 will not work). Then you can combine your data aggregation with photography and save yourself a whole bunch of time.
Photocaster is the best method, as it doesn't have a size-limit. If you use the upload methods that are directly in Web IOL then you want your photos to be LESS than 100kb each and 640x480 in size. If you have a ZIP file, the 100kb 640x480 requirements for each individual photo apply AND the total size of the ZIP file cannot be more than 20mb.
