Limiting CRM Access by Location/IP Addresses
AI Summary
# Summary The original poster raises a security concern about web-based CRM systems and recommends dealerships restrict access to their own IP addresses rather than allowing logins from anywhere, citing a real example where a terminated employee logged in remotely and sabotaged inventory pricing. The thread emphasizes the importance of monitoring login logs and implementing IP-based access controls as a protective measure against employee misconduct before or after departure. Key insight: IP whitelisting and login audit trails are practical security measures that can prevent costly sabotage by disgruntled employees with CRM access.
mattwatson81
Getting Refreshed
Apr 10, 2009
334
10
Matt
One of the positives and negatives with web based software is it can be accessed anywhere.
My question for you is, does your dealership limit access to just the IP addresses of your dealership or can anyone log in to your CRM from anywhere?
I would recommend limiting access to salespeople and perhaps even others to just be within the dealership's network. This helps protect you from from an employee sabotaging your system before or after they leave your dealership.
You should also be able to see a log of when people login and what IP they login from.
I have seen a dealership fire someone and not take their access away and then the employee logs in from home and changes the dealers pricing on their inventory to be below their cost. Not a good deal... but a little IP security can help prevent these scenarios.
Replies Views 0 2,713 Started Last Reply
